03-18-2008 02:26 PM - edited 03-03-2019 09:11 PM
Guys, Im having a problem with a port-channel in a 4506.
I created 2 4-port etherchannels (int port-channel1 and int port-channel2) and all is well. Each of these 2 channels go to 2 Nortel Switches.
When I try to create a third 4-port etherchannel to a third Nortel switch, in theory I was expecting this to be smooth because they all the same, however this 3rd channel will not come up.
I checked the logs in the nortel switch and all clear. However, the logs in the 4506 have these messages:
EC-5-CANNOT_BUNDLE2: Gi4/14 is not compatible with Po3 and will be suspended (trunk mode of Gi4/14 is dynamic, Po3 is trunk)
I've changed ports in the 4506 (from 3/21-24 to 4/11-14) and the exact problems.
Can you guys please help?
thanks in advance
03-18-2008 02:55 PM
Can you check the interface capabilities and ensure that gi4/14 has exactly the same settings as gi4/11 - 13.
switch(config)# int gi4/14
switch(config-if)# sh interface capabilities
Jon
03-18-2008 03:54 PM
they do.
03-18-2008 04:09 PM
Are your symptoms similar to this bug CSCsd11234. If it's try the workaround.
If a physical interface is configured in shutdown mode, then configured with the same configuration including "switchport nonegotiate," when it is later enabled by the no shutdown command, it can not join the bundle and the following error message displays:
%EC-5-CANNOT_BUNDLE2: Gi3/16 is not compatible with Po1and will be suspended (trunk
mode of Gi3/16 is dynamic, Po1 is trunk)
The following configuration sequence will prevent interface g3/16 from joining the bundle:
int g3/16
shut
switchport mode trunk
channel-group 1 mode on
int po1
switchport trunk enacp dot1q
int g3/16
no shut
Workaround: Do NOT configure the channel-port with the same configuration while all physical ports are still in shutdown mode. Instead, issue the unshutdown command on the physical ports to carry over the first unshutdown to the channel port. (CSCsd11234)
Sundar
