Integrating Voice and Data pri with MGCP
Mar 18th, 2008
I know this can be done with the following configuration:
controller T1 1/1
framing esf
linecode b8zs
channel-group 1 timeslots 1-12 speed 64
pri-group timeslots 13-24
However, I cannot seem to find documentation on it on Any help would be appreciated.
Paolo Bevilacqua Thu, 03/20/2008 - 16:37
If you telco can provision that, there is no problem, MGCP won't even know what are the unused PRI timeslots for.
VON CLAWSON Thu, 03/20/2008 - 17:51
right, I know that it will work. What I need is some official documentation indicating that it will work and is supported.
Paolo Bevilacqua Sat, 03/22/2008 - 16:30
Cisco does so many things that is not that you can find confirmation about each and any variation in configuration.
What you want to do is really nothing special and works since some 10 years now. Some people calls it "integrated T1 access"
