Help - New UCM 6.x Install - Phones Won't Register
Mar 18th, 2008
Communications Manager 6.x. None of the phones are auto-registering as configured. I tried to manually add a phone and I'm receiving the following error:
Error Message Update failed. [4924] Request Failed and some License Servers down
The servers are up and active and the licensing counts are normal.
Jaime Valencia Tue, 03/18/2008 - 15:15
  • Cisco Employee,
  • Hall of Fame,
    2011
try restarting the licensing server, then look again under the license report to verify that the info is correct
confirm the CCM.exe is running on the server and try again
javalenc
if this helps, please rate
Brian Carscadden Wed, 03/19/2008 - 07:46
Turns out it was a bug in UCM 6.0.1. related to extension mobility breaking the database connection for registering phones. Upgrade planned for later today. Thanks anyhow!
