Parked calls disappear
Mar 18th, 2008
Sometimes the Parked calls disappear from the screen. The person(s) whose call has been parked, can hear a wait-tone but we can't see or reterive the call. Our CallManager version is 4.2.
Can someone help me to figure out this issue?
Thanks.
Rajesh Revuru Tue, 03/18/2008 - 17:20
I guess your Call Park display timer is very short. You may want to increase that timer. Default is 10 seconds. It is cluster-wide parameter.
Check the following
Setting the Service Parameters for Call Park
Cisco CallManager provides two clusterwide service parameters for call park: Call Park Display Timer and Call Park Reversion Timer. Each service parameter includes a default and requires no special configuration.
•Call Park Display Timer-Default specifies 10 seconds. This parameter determines how long a call park number displays on the phone that parked the call. Set this timer for each server in a cluster that has the Cisco CallManager service and call park configured.
•Call Park Reversion Timer-Default specifies 60 seconds. This parameter determines the time that a call remains parked. Set this timer for each server in a cluster that has the Cisco CallManager service and call park configured. When this timer expires, the parked call returns to the device that parked the call.
Note To set the timers, choose System > Service Parameters and update the Call Park Display Timer and the Call Park Reversion Timer fields in the Clusterwide Parameters (Feature-General) pane.
