ASA5505 port redirect for 443 to inside IP fails 3-710003 msg
Mar 18th, 2008
I have a ASA5505 configured with PPPoe/ADSL and one fixed IP address on the outside. I want allow port 443 to an inside host using the static command and port redirection for OWA on exchange. I have setup the ACL and static map but get the 3-710003 error which I believe is due to the HTTP/HHTPS server using this port for ASDM access and this not being configured on the outside interface. Is there way to get around this so that I can use 443 on the ouside interface?
Jay Johnston Mon, 03/24/2008 - 11:26
You'll need to change the port that the ASA's http server listens on.
Try using the command like this:
ciscoasa(config)# http server enable 444
Then the packets should match the translation.
