ASA 5510 Sec Plus Lan-2-Lan -> 1841 phase 2 problem ?
Mar 18th, 2008
Hi all,
I got a problem with a Lan-2-Lan connection from my Active/standby 5510's with Sec Plus License
the config on the firewall is this
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 1 set transform-set ESP-AES-256-SHA ESP-AES-256-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-128-SHA ESP-AES-128-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 1 set reverse-route
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-256 -SHA ESP-AES-256-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-128-SHA ESP-AES-128 -MD5 ESP-3DES-SHA ESP-3DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set reverse-route
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer 1.1.1.1
crypto map Outside_map 1 set transform-set ESP-AES-256-SHA ESP-3DES-SHA
crypto map Outside_map 1 set reverse-route
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 20
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 30
encryption aes-192
hash sha
group 5
lifetime 86400
crypto isakmp policy 40
encryption aes
hash sha
group 5
lifetime 86400
crypto isakmp policy 60
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash md5
group 2
lifetime 86400
no crypto isakmp nat-traversal
crypto isakmp disconnect-notify
and on the router is here
encr aes 256
group 5
encr 3des
group 2
crypto isakmp key key-here address 10.10.10.10
crypto isakmp keepalive 30
crypto ipsec transform-set strong-des esp-3des esp-sha-hmac
crypto ipsec transform-set FrasersVersion esp-aes 256 esp-sha-hmac
crypto ipsec transform-set fraser2 esp-aes esp-sha-hmac
crypto map VPN 1 ipsec-isakmp
set peer 10.10.10.10
set transform-set FrasersVersion strong-des fraser2
set pfs group2
match address 150
but I still get errors such as the Log File below.
As soon as I let it build the tunnel all works fine but then a few seconds later it all falls down :-(
What am I missing ?
Please help.
aabdullah25 Wed, 03/19/2008 - 05:18
Since you have not given the full config, i think there is an issue with your peer IP's and also crypto ACL (as per logs).
From your ASA config, the set peer is 1.1.1.1 but from LOG it shows as 11.11.11.11 and pls check the crypto acl also.
rgds
Fraser Reid Wed, 03/19/2008 - 07:50
here is a little more info than before....
As before the Phase 1 and Phase 2 work - data passes over the tunnel but then all just drops and what I see in the log is what you have here in the above attachment.....
