BRI dialling issue
shiva_jay
I have 2 offices at diffrent locations, both the offices are connected through ISDN BRI link (128 kbps). I have a 2811 router at the head office and an 1841 router at the remote office. I have configured it in a dial on demand mode. The IDSN bri connection is provided by 2 diffrent service poviders one at each end. I have a problem now, that even if connect a machine from my HO to remote office the dialling is done only at the router at the remote end. i have set 600 secs as idle time out in both the routers, how does this happen... please advice
13 Replies 13
gunner07971
Can you post the configs of both routers so we can take a look please.
Dear sir,
This is the remote routers config....
Current configuration : 2790 bytes
version 12.4
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip dhcp use vrf connected
ip domain name yourdomain.com
isdn switch-type basic-net3
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 172.16.12.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clockrate 2000000
interface BRI0/1/0
bandwidth 128
ip address 10.10.10.1 255.255.255.0
encapsulation ppp
dialer idle-timeout 600
dialer map ip 10.10.10.2 name Headoffice speed 56 04442641300
dialer map ip 10.10.10.2 name Headoffice speed 56 04442641301
dialer load-threshold 100 outbound
dialer-group 1
isdn point-to-point-setup
ppp authentication chap
ip classless
ip route 172.16.10.0 255.255.255.0 10.10.10.2
ip route 192.168.1.0 255.255.255.0 10.10.10.2
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 100 deny ip any host 255.255.255.255
access-list 100 permit ip any any
access-list 100 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 172.16.12.0 0.0.0.255 172.16.10.0 0.0.0.255
dialer-list 1 protocol ip list 100
control-plane
This is the Head office routers config...
sh run
Building configuration...
Current configuration : 3149 bytes
version 12.4
hostname HeadOffice
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 172.16.10.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 172.16.1.1 255.255.255.252
encapsulation ppp
interface Serial0/0/1
ip address 20.20.20.1 255.255.255.252
encapsulation ppp
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
interface BRI1/0
bandwidth 128
ip address 10.10.10.2 255.255.255.0
encapsulation ppp
dialer map ip 10.10.10.1 name router speed 56 broadcast08772262344
dialer-group 1
interface BRI1/1
no ip address
shutdown
ip route 172.16.11.0 255.255.255.0 172.16.1.2
ip route 172.16.12.0 255.255.255.0 10.10.10.1
ip route 172.16.13.0 255.255.255.0 Serial0/0/1
ip route 172.16.13.0 255.255.255.0 20.20.20.2
ip route 192.168.3.0 255.255.255.0 10.10.10.1
ip http server
control-plane
Hi Shiva, are you using this BRI as the backup interface? If same, then you need to put the backup interface (BRI interface) under primary interface (serial interface). Thanks Goutam
No iam not using BRI as a backup interface.
Hi, you can try the bellow:
1.Set the user name & password to the both router for the “ppp authentication chap” to authenticate the routers. i.e.
username router password XXX
username HeadOffice password XXX
2.You can remove the “speed 56” into the 'dialer map' command
Also requesting you pls run the debug and post.
Thanks Goutam
Hi, have you tried? You can visit http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a00800943ad.shtml
For your reference.
Thanks Goutam
Dear Goutam,
Iam able to connect and also able to move datas from both sides, but the issue is that l even though i connect my remote office from head office the dialling is happening on my remote end router not on my head office router. Please advice
Jagan
Hi Jagan, Your remote-office can generate the interesting traffic? Pls inform. Goutam
Shiva,
Ensure your dialer map is correct on your Head office site.
Standard ISDN debug commads should help.
Debug isdn q931
Degug isdn q921
Try doing an ISDN test call from the Head office router to the remote office to ensure that all is OK.
isdn call interface bri 1/0 08772262344
On the Head Office use the debug dialer command to see if your dialer list is the source of the problem.
You may also want to check debug ppp negotiations.
Goutam Sanyal
Level 4
Level 4
Hi Shiva, do you have ISDN Ph? If you have, can you able to dial the isdn no to other end or vice-versa? Is the “sh isdn status” is okay, mean layer 2 is active with multiple frame established? If you can - requesting you to post the configuration along with debug isdn q931
or
you can visit
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf9b1d
Thanks Goutam
Jagan
I have looked at the configs that you have posted and assuming that they are complete then I do not see what is preventing the head router from dialing. Can you tell us very specifically what you are doing at the head office to bring up the BRI connection to the remote office?
Rick
Rick
Dear rick,
We have 2 service providers one for the head office and the other for the remote office. The head office router is configured as to dial the remote office isdn number when triggered, in the same manner the remote office router(1841) is confugured with the head office isdn number to connect when triggered
We are using this connection for transfering our managemnet,accounts datas and also to solve some hardware and network related issues through Remote desktop and Remote admin tool.
The configuration is done to cutoff the router after 600 secs if idle
Now when i try to connect my remote end machine from head office the dialing is done by the remote end router. My monthly ISDN bill at the remote office is very high whereas i dont receive any usage cost at my head office.
How does this happen... I have no clue on this
Jagan
Jagan
I asked for specifics about what you do at the head office router to initiate the connection. I would like to know what is the trigger - specifically I would like to know what kind of traffic it is (is it ping, or RDP, or what) and to what destination address. Can you provide that information?
Rick
Rick
