Bridging the same subnet over a WAN link
Mar 19th, 2008
We have the following:
Two sites connected over MPLS backbone.
We need to configure one subnet in both locations and have this subnet spanned across the WAN.
The reason for this is we have a security system that needs to monitor both sites using a private IP subnet. the security servers can be connected to 3750 switches in both locations.
Any simple solutions?
Jon Marshall Wed, 03/19/2008 - 05:57
You could talk to your Service provider and see if they support virtual pseudowires which is a L2 P2P link over a L3 MPLS network. Attached is a link to some info on MPLS L2 VPN's.
Alternatively you can use L2TPv3 and configure this yourself.
ziutek Wed, 03/19/2008 - 06:04
We do not want to modfy our MPLS connections.
Can L2TP be runn between 2 L3 ports on the 3750s?
Thanks for the advice.
Paolo Bevilacqua Wed, 03/19/2008 - 07:26
I suppose the "security server" insists on having the systems on a directly connected lan and would not work otherwise ?
I so there is a simple way to fool it while keeping a regular routed network.
Suppose the two locations are numbered and 10.0.34/24.
On the picky server configure and address that falls in local network, but netmask /16. It will belive all the systems are local. The router will answer to requests by proxy-arp and it thing should work normally.
Jon Marshall Wed, 03/19/2008 - 08:05
I don't believe L2TPv3 is supported on 3750 switches. So unless you talk to your SP you are limited in what you can do.
ziutek Wed, 03/19/2008 - 08:15
What about ethernet subinterfaces? The L3s are each behind a 2811. Could I run L2TP between the 2 2811s, with the end points on ethernet subinterfaces?
Jon Marshall Wed, 03/19/2008 - 08:16
Yes you could as long as the network you are trying to bridge terminates on the subinterface on each respective 2811.
wilson_1234_2 Wed, 03/19/2008 - 16:00
Just a curiosity question:
Do bridged connections no work across mpls?
Only point-to-point?
We have a site bridged across a point-to-point that is in the same subnet on the remote side as the local side.
Jon Marshall Wed, 03/19/2008 - 16:07
MPLS supports 2 types of L2 bridging
1) Virtual pseudowire - a P2P layer link running over a L3 MPLS network
2) VPLS - a many to many L2 network ie just like ethernet extending across a L3 MPLS network.
So you can bridge vlans across MPLS. These 2 are provided by the service provider of the MPLS cloud.
You can also use L2TPv3 where you can bridge a vlan between 2 of your routers on at either end. The service provider is not needed here.
Hope this makes sense
