CTM8 doesn't work after java update
Answered Question
Mar 19th, 2008
We have a sun fire v240 with solaris 10. After an update of java jre and jdk from 1.5.0_14 to 1.5.0_15 ctm 8 stopped. I tried a reboot of the server without success.
The error-message if i start ctm with 'ctms-start' is:
Exception in thread "main" java.lang.NoClassDefFoundError: org/bouncycastle/openssl/PasswordFinder
at com.cisco.stardm.platform.Decrypt.main(Decrypt.java:65)
Error in add_log_parts.sh
Add log partition error : Please Check if ORACLE is installed and CTM DB is running
**Abort** ctms-start
The database is running. I did removed the jre and the jdk again, but it still wont start.
I don't want to install the ctm again.
Can somebody help me?
Correct Answer by Michael Dooley about 9 years 3 months ago
Well that sounds interesting.... The error message is telling us that CTM Server will not start because it thinks oracle is not running. What do you get if you do the following command?
#ps -elf | grep oracle
You should see a bunch or lines with oracle in it. If you just see one line, then oracle is not running and you need to see why.
If it is not running, have you tried to reboot the server?
Mike Dooley
Cisco Heartland TAC
Correct Answer
Michael Dooley Tue, 03/25/2008 - 09:05
  • Cisco Employee,
Mike Dooley
Cisco Heartland TAC
tortifoerster Wed, 03/26/2008 - 03:06
I could solve the problem last days.
My solution:
After some brainstorming and google, i did understand the message.
With the update of java jdk, java seems to delete an external libary and a java security entry, which were done by ctm-installation.
1. I did download the original bouncycastle-jar 'bcprov-jdk15-138.jar' from the internet and moved it to the java-libary-folder for external jars.
2. I needed to change the java-security-file because of a missing BN-key. I add the following line:
'security.provider.8=org.bouncycastle.jce.provider.BouncyCastleProvider'
After these 2 changes, I could start the ctm-server with 'ctms-start'.
So, if I update the jdk next time, I know what I have to do.
