ICMP trough ASA
Mar 19th, 2008
I need help in understanding if ICM works with PAT.
1. I have network 192.168.2.0 configured on inside interface which will act as DHCP server to allocate IP's
2.I have network 10.x.x.x on outside interface.
3.FTP/TFTP server(10.x.x.145) is located in the outside network.
4.Inside users should be able to do only ftp/tftp to ftp/tftp server
5.Inside network should be patted using the outside interface
6.ICMP should be allowed so that inside hosts should be able to ping the ftp servers
Let me know whats is the access-list that has to be applied to allow ftp.tftp and icmp and on which interface
wasiimcisco Wed, 03/19/2008 - 08:24
access-list prv_outside extended permit icmp host 10.0.0.145 192.168.2.0 255.255.255.0 echo-reply
access-list prv_outside extended permit tcp host 10.0.0.145 192.168.2.0 255.255.255.0 eq ftp
access-list prv_outside extended permit tcp host 10.0.0.145 192.168.2.0 255.255.255.0 eq ftp-data
access-list prv_outside extended permit tcp host 10.0.0.145 192.168.2.0 255.255.255.0 eq 69
access-list prv_inside extended permit icmp 192.168.2.0 255.255.255.0 host 10.0.0.145 echo
access-list prv_inside extended permit tcp 192.168.2.0 255.255.255.0 host 10.0.0.145 eq ftp
access-list prv_inside extended permit tcp 192.168.2.0 255.255.255.0 host 10.0.0.145 eq ftp-data
access-list prv_inside extended permit tcp 192.168.2.0 255.255.255.0 host 10.0.0.145 eq 69
access-list prv_inside extended permit ip 192.168.2.0 255.255.255.0 any
access-group prv_outside in interface outside
access-group prv_inside in interface inside
static (inside,outside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
nat (inside) 1 192.168.2.0 255.255.255.0
global (outside) 1 interface
try it out and let me know
