CME and 7941 IP phone
Mar 19th, 2008
I am trying to configure a 1741G phone in CallManager Express 4.2. When I attempt to type "load 7941 SCCP41.8-2-2SR2S.loads", the system doesn't accept it. The only valid options are the older, non 79x1 phones.
Also, I cannot tell the ephone configuration that the phone is a 7941. I have to define it as a 7941.
Any ideas?
Thanks!
Paolo Bevilacqua Wed, 03/19/2008 - 07:00
  • Hall of Fame,
    Founding Member
Hi, please configure
load 7941 7941 SCCP41.8-2-2SR2S
Also which exact image do you have, suggest you run XW6 as the previous ones are very buggy.
tmoffett Wed, 03/19/2008 - 07:10
Thanks for the reply. I am actually unable to enter load "7941"
Here are my options, on a different kit
router(config-telephony)#load ?
12SP Select the firmware load file for 12SP+ and 30VIP phones
7902 Select the firmware load file for 7902
7905 Select the firmware load file for 7905
7910 Select the firmware load file for Telecaster 7910 phones
7912 Select the firmware load file for 7912
7914 Select the firmware load file for sidecar 7914
7920 Select the firmware load file for 7920
7935 Select the firmware load file for 7935 Conference Station
7936 Select the firmware load file for 7936
7960-7940 Select the firmware load file for Telecaster 7960 & 7940 phones
7970 Select the firmware load file for 7970
7971 Select the firmware load file for 7971
ATA Select the firmware load file for ATA
I don't have my demo kit fired up right now, but the output above is from a 2821 running 12.4(3g) (c2800nm-advipservicesk9-mz.124-3g.bin). CME version is 3.3...
Paolo Bevilacqua Wed, 03/19/2008 - 07:15
  • Hall of Fame,
    Founding Member
Hi, please upgrade IOS, I recommend 12.4(11)XJ4.
