CIPC xmldefault.cnf.xml CallManager Version 4.1
Mar 19th, 2008
Anyone know when this file is generated.
I am having auto registration issues with an IPC. I have seen within status on the softphone that it is trying to access it's sep CNF as the above is unavailable any idea's?
smalkeric Tue, 03/25/2008 - 09:11
Configuration files (.cnf.xml) reside on the TFTP server and define parameters for connecting to Cisco Unified CallManager. In general, any time you make a change in Cisco Unified CallManager that requires a device to be reset, a change has been made to the device's configuration file. . If you have enabled auto-registration in Cisco Unified CallManager, Cisco IP Communicator accesses a default configuration file (xmldefault.cnf.xml) from the TFTP server. . Otherwise, Cisco IP Communicator accesses a .cnf.xml file corresponding to its device name.
