03-19-2008 07:46 AM - edited 03-03-2019 09:12 PM
Have a Cisco2821 with a vwic2-1mft-e1 card. Trying to setup for data calls. Just recently upgraded the IOS to (C2800NM-ENTSERVICES-M), Version 12.4(15)T3 -- previous version was (C2800NM-ENTBASE-M), Version 12.4(15)T3. Trying to test data calls but unable to enter the 'pri-group time 1-31' under the controller.
No voice calls going to be done - and no DSP resources are needed - only hdlc resources.
This is what is output from the command:
ssago-atm-isdn(config)#contr e1 0/0/0
assago-atm-isdn(config-controller)#pri-group timeslots 1-31
% Not enough DSP resources available to configure pri-group on controller E1 0/0/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 2 extra dsp(s) are required to create this voice port.
Please advise. Thanks.
Attachment has 'sh ver', 'sh run' and a 'sh diag'
03-19-2008 08:53 AM
The thing is PRI on the VWIC is meant for voice primarily, so the requirement for DSP.
There's a workaround however, load an image without voice support, like ip base. That way you will be able to configure pri w/o DSP.
03-19-2008 09:02 AM
Thanks for the reply. The customer had upgraded to the EntServices from the EntBase. Under the EntBase he was able to enter the pri-group but the data calls were failing.
eb 28 11:21:49.737: ISDN Se0/1/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=55 nr=82
Feb 28 11:21:49.737: ISDN Se0/1/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=56
Feb 28 11:21:49.741: ISDN Se0/1/0:15 **ERROR**: accept_incoming_data: no hdlc available from controller b channel 3, call id 0x1D
Feb 28 11:29:16.138: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1100
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838D
Preferred, Channel 13
Calling Party Number i = 0x2183, '731616019'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '257517582'
Sending Complete
Feb 28 11:29:16.138: ISDN Se0/1/0:15 **ERROR**: accept_incoming_data: no hdlc available from controller b channel 12, call id 0x25
Feb 28 11:29:16.142: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9100
Channel ID i = 0xA9838D
Exclusive, Channel 13
Feb 28 11:29:16.142: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x9100
Cause i = 0x80A2 - No circuit/channel available
Feb 28 11:29:16.206: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x1100
Feb 28 11:29:16.206: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9100
snippet of config (he also initially had 3 cards in - only one active)
controller E1 0/0/0
controller E1 0/1/0
controller E1 0/2/0
interface GigabitEthernet0/0
ip address 10.16.18.9 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation ppp
shutdown
dialer rotary-group 55
dialer-group 3
no snmp trap link-status
isdn switch-type primary-net5
isdn bchan-number-order ascending
interface Serial0/1/0:15
no ip address
encapsulation ppp
dialer-group 3
interface Serial0/2/0:15
no ip address
encapsulation ppp
shutdown
interface Dialer55
bandwidth 64
ip address 10.12.16.17 255.255.0.0
encapsulation ppp
dialer in-band
dialer idle-timeout 360
dialer map ip 10.12.48.189 name smaran377502 012345678
dialer-group 3
ppp authentication chap
Any ideas? Sorry for changing the issue midstream.
03-19-2008 09:20 AM
Hi, really it's a bit of grey area, because the "official" cisco card for data PRI on the ISR are NM-xCE1/T1-PRI and more recently the HWIC-PRI.
I have one router installed working for data PRI with VWIC2 if I'm not wrong however, I will check which exact image it has.
