RME 4.06: default email subject in syslog AA
Mar 19th, 2008
Hi folks!
I've a little problem with the email subject in Tools -> Syslog --> Automated Actions:
Automated Action Type.
I've set a new email subject, different from "CW RME Syslog AA". I have saved it and a new AA was created!
The problem is, if I edit again the AA type, it show me the default subject wich is "CW RME Syslog AA"!! But I've setted a new subject that now is lost! :(.
Is this bug notes to cisco?
Any helps would be appreciate.
TKS a lot
Leonardo
Joe Clarke Wed, 03/19/2008 - 11:49
This is a new bug, CSCso31296. I have created a patch for this, but you will need to contact TAC to obtain it. Have your engineer contact me directly to get the patch.
leorob123 Thu, 03/27/2008 - 10:21
Hi Joe,
the TAC told me that the patch is good for 4.1, but I have RME 4.0.6.
Infact the patch provided me, doesn't work!
Leonardo
Joe Clarke Thu, 03/27/2008 - 11:00
No, the patch I wrote is for RME 4.0.6, and it does work with 4.0.6. I tested it numerous times myself. Make sure you applied it correctly, and restarted dmgtd after doing so.
