copy/cut paste to USB
Mar 19th, 2008
I have a rule in place to deny all application to write to @removable:\** . I assumed this would block anything going to them. I can't do a save or a save as to the USB but I can copy/cut and paste and drag and drop to it. Any ideas on blocking the copy/cut and paste and drag and drop?
Thanks in Advance...
bruce_sprenger Wed, 03/19/2008 - 12:49
Won't let me save it. I type it in that way and hit save and it changes it back to @removable:\**
tsteger1 Wed, 03/19/2008 - 13:33
This is a File Access Control rule, correct?
Does it generate an error or alert when it fails?
If so, try creating a new one from scratch.
bruce_sprenger Wed, 03/19/2008 - 13:38
Yes it is a File Access Control rule.
No, it doesn't generate an error or alert.
should I try a new rule still?
tsteger1 Wed, 03/19/2008 - 14:31
I think so yes. I'm not sure what the problem might be.
I was able to create one and it worked properly.
tsteger1 Thu, 03/20/2008 - 07:55
I used @removable\**\* (it actually changes mine to that when I create the rule no matter what I put).
This is after it warns me with:
Warning: Dangerous application class/file selection (might render the system unusable).
What version?
