Spain PRi configuration
Answered Question
Mar 19th, 2008
Hi all,
does anyone knows what are the paremeters for configure a Pri line throught MGCP in a Callmanager?
(PRI Protocol Type, line codinf, framing, ...)
thanks in advance
Correct Answer by Paolo Bevilacqua about 9 years 1 week ago
Like all European contries, switchtype primary-net5, linecode hdb3, framing usually crc4.
hope this helps, please rate post if it does!
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Wed, 03/19/2008 - 09:33
  • Hall of Fame,
    Founding Member
carlosjlopez Wed, 03/19/2008 - 09:38
that's correct, the problem was that I selected a T1 interface instead E1 one. therefore this parameters didnt appear. Now it's correct.
thank you very much for your faster answer.
Paolo Bevilacqua Wed, 03/19/2008 - 09:40
  • Hall of Fame,
    Founding Member
You're welcome, please remember to rate posts using the scrollbox below!
carlosjlopez Wed, 03/19/2008 - 09:59
thanks again,
Do you Know how can I receive all calls (from this Pri line) in a Line Group?
The MGCP gateway is configured.
The line group is Configured.
