Higher level access on the cisco prep center
Mar 19th, 2008
I have just finished with a data communications degree and am studying for my ccna. I have bought cisco books and the net simulator. I am not currently a part of an cisco partners however I am seeking to gain higher level access on the ccna prep center other than user access, is there any way to get higher level access so that I may have access to better learning material?
Roger Kessler
Hi Roger
Firstly congratulations on getting your degree and good luck with the future studies and obtaining Cisco certification.
As far as higher level access to the CCNA prep center is concerned, I don't believe that there are different levels of access to the prep centers.
There are however different levels of CCO account from the basic, which gives you access to the prep center and these forums up to a level where you can download IOS software and access documentation. However this level of CCO account is pretty expensive AFAIK, but are not required to access the prep center.
Best Regards,
Michael
