CCM 5.1 Directory Printout
Answered Question
Mar 19th, 2008
Is there a nice way to get a CSV or similar file/printout of the Directory Numbers, and associated descriptions from the CCM database?
Correct Answer by sheepate about 9 years 4 months ago
Call Routing>>Route Plan Report>> Hit find with blank search string.
After the results are displayed, From top right corner Select "View in File" and hit go. You will get the CSV.
HtH
Overall Rating: 5 (1 ratings)
Correct Answer
sheepate Wed, 03/19/2008 - 11:47
HtH
