Help to introduce WAE
Mar 19th, 2008
Is available 2 wae-612, I wish them to put in different cities. Now in these cities there are routers on freebsd. I wish to put on one wae about a router and somehow to direct from them the traffic on wae.
Has read the documentation with cisco, there it is written that it is necessary to have 1 more wae for central-manager.
It is possible-whether to do without somehow central-manager as to buy one more wae there is no possibility. And how to direct the traffic from a router on wae.
Manoj Wadhwa Fri, 03/21/2008 - 12:59
In order to redirect traffic from router to WAE, you can use WCCP which is a transparent caching mechanism. On WCCP configuration, you can define what all protocols you need to forward to WAE. Thanks!
BR,
Manoj
slava_ram Sun, 03/23/2008 - 09:01
And can-whether freebsd do a redirection wccp 61 and 62 as it is written to documentation?
Thanks!
