radius config
Answered Question
Mar 19th, 2008
I am trying to set up Radius on a cat4506 with IOS version 12.2 but none of the radius-sever commands work. There isn't anything about radius when using the "?" in config mode. Any ideas?
Correct Answer by andrew.butterworth about 8 years 11 months ago
You need to enable aaa by entering the command:
aaa new model
After that the aaa authorization, authentication and accounting commands should be available as well as the radius-server commands.
Andy
Overall Rating: 5 (1 ratings)
Correct Answer
andrew.butterworth Wed, 03/19/2008 - 13:17
aaa new model
Andy
francisco_1 Wed, 03/19/2008 - 14:09
see below for full radius config. the config will also fallback to local authentication if your radius server is down.
aaa new-model
radius-server host (your radius server ip) auth-port 1812 acct-port 1813
radius-server key (your radius secret key
radius-server source-ports 1645-1646
username **** password ******
aaa authentication login default group radius local
aaa authentication login console local
Franco
Please rate if this helps.
