CE520 switches can only be configured from Cisco Configuration Assistant??
Mar 19th, 2008
Am I missing something or is it true that you can only configure a CE520 switch with the Cisco Configuration Assistant?? After I set it up with the Express Setup, I clicked on configure and only got an advertisment to download CCA??
Paolo Bevilacqua Wed, 03/19/2008 - 12:27
CCA is not required. You access the web service via browser, and all can be done is there.
Note if you need is L2 PoE switch of reasonable cost, nos cisco has finally release the ws-2960-24pc-l, it costs a tad more than the ce520/500w switches, but it has a regualt CLI and does everything a cisco switch is supposed to do.
tcekada Wed, 03/19/2008 - 12:42
With the CE500 switches I found this to be correct, but believe me I have a brand new CE520 with 12.2(37)IOS on it, and the only thing you can do when you browse to it is the Express Setup part. You cannot setup VLANs or change port settings in the Web Browser. The Install/Upgrade docs seem to confirm this.
Thanks anyway,
Paolo Bevilacqua Wed, 03/19/2008 - 13:40
OMG, I believe that and I think that is a major step back in product usability. Hope you can find a way around that, perhaps loading a CE500 image could help ?
For sure I'll never ever buy a product that requires to install an application to set the very few things it does.
mciarfello Wed, 05/14/2008 - 05:26
The exec "backdoor" is still there: http://ip-addr/exec but is no substitute for a real CLI.
My vote for it looks like you need the Configuration assistant to configure the switch. 68MB.
