Problem in show ip route?
Is someone who can help me? What is the meaning of the result "%Network not in table"?
Router>show int serial1
Serial1 is up, line protocol is down
Hardware is MK5025
Description: ****Example****
Internet address is 192.168.1.1/30
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, rely 131/255, load 1/255
Encapsulation PPP, loopback not set, keepalive set (10 sec)
LCP Listen
Closed: IPCP, CDPCP
Last input 00:07:58, output 00:00:14, output hang never
Last clearing of "show interface" counters 12:50:32
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/75/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
92 packets input, 7719 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
29464045 input errors, 29253742 CRC, 0 frame, 210307 overrun, 0 ignored, 0 abort
9611 packets output, 134554 bytes, 0 underruns
0 output errors, 0 collisions, 2415 interface resets
2451 carrier transitions
Router>show ip route 192.168.1.1
% Network not in table
Router>
The Serial interface is not up/up, it sees a physical connection but no protocol.
The connected 192.168.1.1 address will only be in the routing table if interface and line protocol are both up.. This is a PPP encapsulated interface and it appears possible the other end of the PPP link isn't uup or configured properly.
