Excluding address in DHCP pool
Answered Question
Mar 19th, 2008
I thought I knew how to exclude an addres..
but im not familiar with the SDM statements found in the config..
If I wanted to exclude 192.168.22.99..how would i confiugre this?
ip dhcp excluded-address 192.168.22.99 ?
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.22.1 192.168.22.10
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool sdm-pool1
import all
network 192.168.22.0 255.255.255.0
dns-server 192.168.1.27
default-router 192.168.22.1
netbios-name-server 192.168.119.2 192.168.117.15
netbios-node-type h-node
Correct Answer by Edison Ortiz about 8 years 10 months ago
Per the link I posted:
"Manually configured DHCP option parameters override imported DHCP option parameters"
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 03/19/2008 - 18:04
Yup, is that simple :)
HTH,
__
Edison.
nygenxny123 Wed, 03/19/2008 - 18:42
thx!
I was doing research regarding the "import all"
command. Does this have to do with the
far end router? What exaclty does this command do?
This document makes it sound like it is getting configuration from the "core" router
http://www.cisco.com/warp/public/105/dhcp_ser.html
And is sdm simply a default statement when configuring dhcp?
nygenxny123 Thu, 03/20/2008 - 06:29
Thx Edison,
Since we are bringing in options from another DHCP router with the "import all" command-does
this void out what is configured on this particular router.
ip cef
import all
lease 0 2
import all
Correct Answer
Edison Ortiz Thu, 03/20/2008 - 07:12
