Media Master Toolbar in Unity 4.2 will not record
Mar 19th, 2008
I'm trying to set up a basic call handler menu system. The Media Master toolbar loads and I can set the options I want. It's set up to use my IP phone as the record/playback device. The extension and server IP are set. When I press record, the system calls my phone but will not record a message. I don't even get the beep that announces the recording has started. The cursor flashes back and forth between the pointer and an hour glass. I cannot stop the attempted recording but after a minute or two it stops by itself. I have tried it on two seperate machines one running IE 6 and the other IE 7.
DCOM is running on both machines and I have removed and reinstalled the activex control. Neither is running a firewall and I even tried disabling the antivirus in case it was interfering with DCOM traffic.
Anyone run into this?
