Help with block a range of port to an IP
We have a Cisco 1841.
Fast0/0 with 30.104.104.2 (IP to ISP)
FAST0/1 with 30.103.103.129/27 (our public ip block)
I like to specifically block any incoming (from internet) access from port 1-1024 to only 30.103.103.135 (one of our public systems)
How can I do that?
I have tried:
access-list 101 deny tcp any lt 1025 host 30.103.103.135
the moment I apply it to either fast0/0 or 1, it cut all access. could someone help?
Thanks in advance
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 03/19/2008 - 13:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Okay firstly there is an implict deny at the end of any access-list so you need to modify your access-list to
access-list 101 permit ip any any
Secondly this access-list is blocking any IP address on port 1 -> 1024 connecting to 30.103.103.135 on any port. Is this what you actually want or do you want to stop any IP connecting to 30.103.103.135 on ports 1 -> 1024 ?
Jon
Richard Burts Wed, 03/19/2008 - 19:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ken
In your case I believe that the same access list could be used on either FA0/0 or on FA0/1. On FA0/0 (connecting to ISP) it would be applied as inbound. On FA0/1 (connecting to your LAN) it would be applied outbound.
Rick
Jon Marshall Thu, 03/20/2008 - 00:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ken
Agree with Rick on which direction to apply.
I am still unsure as to which ports ? When you say port 1 -1024 is that
1) ports 1 - 1024 on any IP connecting 30.103.103.135 ie. the source port from any IP
or
2) ports 1 - 1024 on 30.103.103.135
If 1) your access-list is correct
If 2) you need to modify
access-list 101 deny tcp any host 30.103.103.135 lt 1025
Jon
Richard Burts Thu, 03/20/2008 - 11:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ken
I am glad that you got it working. Thanks for posting back to the forum, indicating that it was working and what you did to get it to work. It helps the forum when we can see the solution to the issue that was raised.
Rick
