Download Topology to Visio
Mar 19th, 2008
I have a Windows 2000 Server with LMS 2.6, Campus Manager 4.0.9. One of my users reports that he cannot export the topology view to Visio. I have polled my other users and they can export the Visio file; as well as I can download in either format, csv or xml. Is there a Windows configuration on his machine (Windows XP SP 2)that would or could result in an authentication error? We thought that it might be a Java problem, but he has the same update as we all do.
Overall Rating: 4 (2 ratings)
Joe Clarke Wed, 03/19/2008 - 16:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Is the LMS server integrated with ACS? Exactly what error is this user getting? If the user logs into LMS from another, working client, does he get the same error, or does it work (i.e. does the problem follow the user or the client)?
PYomes0930 Thu, 03/20/2008 - 08:11
Jclarke,
No the LMS is not integrated with ACS. The strange thing about the situation is that the error only occurs with one user. We had him signed into another machine, and the export works there. He says that he updated to a recent issue of Java, but the same thing happens. The Campus Manager error is:
IO Error exporting to File "," for window "Network Topology - Layer 2 View
com.cisco.nm.client.SecurityException: Not Authenticated
The error occurs when he tries to export to .csv. When he tries to export to .xml it does nothing. Probably because he has a newer version of Visio, correct?
Thanks for the help,
PYomes0930
Joe Clarke Thu, 03/20/2008 - 08:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of Java does this user have loaded on his machine? With Campus Manager 4.0.9, you can only have 1.4.2_12. If he has any other versions, have him uninstall all Java from his workstation, then install the plug-in from the server. Then have him check the Java control panel, and remove all the certificates under the Certificates tab.
Then have him reconnect to Campus Manager. When he sees a security pop-up, have him accept it (or trust Cisco). Then have him try the Visio export.
PYomes0930 Thu, 03/20/2008 - 08:59
Jclarke,
My user did as you instructed above, and the situation has been resolved. I will award max points and close this issue out when you reply. Thank you very much for your quick responses and expertise.
Pyomes0930
