03-19-2008 09:14 PM - edited 03-03-2019 09:12 PM
i wanted to know that i have cable internet at home how can i access my router from office
my router is a 2620 which has 1-wicT and isdn briU in its slots
where do i connect the internet connector which is coming from a modem
what is Isdn BRI U module used for?
and what is the AUX port on the
router used for?
Please help me out
Solved! Go to Solution.
03-23-2008 10:18 PM
Hi Gursaran,
Where you want to attach WIC1T? PC or Router?
Its use for Cisco Router only.
When your PC is connected via EIA/TIA 568 to the Internet, then you can access your office equipment (Cisco Router/Switch), but for that you need a Public IP to your office Equipment. Doing the same you can telnet/SSH from your home.
WIC1T is required for router to carry the serial connection. V.35 provides the clocking for the DTE interface, which is WIC1T or Cisco Router's Serial Interface.
Goutam
Please rate if I am Informative!!!
03-19-2008 10:32 PM
Hi Gursaran,
Your post is not sufficient to make any reply.
I am assuming that if you have a public IP for your office Internet, if you have the same than you can access your router from outside of office.
As per you next part also I am assuming that the modem is V.35, then you need to connect it at serial port 1-WICT.
Also I am assuming that you are familiar with ISDN reference points, i.e. R, S, and T. For the ISDN âUâ reference point is basically between NT1 devices and line-termination equipment in the carrier network.
The purpose of the AUX port is use for Asynchronies connection. You can connect a Asynchronies Modem to login to the router.
For more details for ISDN you can visit :
Goutam
Please rate if I am informative!!!
03-20-2008 10:52 AM
i apreciate your response gautam
what i have at home for internet is digital broadband box from which a cable which is Tia/Eia 568 runs to my computer ethernet port
the connectors at both look like an RJ45 but a slightly bigger
do i still need to attach to the wic1t or not
how does it work?
One thing by external IP address you mean internet right?
please guide me cause everything i learn is from here
Thanks a lot
how do i come to know the modem is v.35 or not
one th
03-23-2008 10:18 PM
Hi Gursaran,
Goutam
03-24-2008 08:18 AM
i appreciate your response
v.35 is cable standard right which connects to DCE Right?
what is the differece between a serial and ISDN connection
can anybody please help me with that?
03-24-2008 08:33 AM
Already replied here:
Please keep same questions into a single thread to not disperse dicssuins and answers.
03-24-2008 10:55 PM
STRANGE !!!
