03-19-2008 10:38 PM - edited 03-18-2019 08:38 PM
Hi!
I want to bind the call manager administrator login with the ip of the PC,Say the PC's ip is 20.30.28.1 .i.e i want that if anyone wants to login to the CCM who is having the privileges of administrator he can do that from a particular PC only which is having the ip 20.30.28.1
IS it possible? If yes then how to do that?i am using call manager 4.1
Thanks.
03-20-2008 08:01 AM
This is not possible within Callmanager, however, you could use an ACL on a router/switch within your network to accomplish this.
Hope this help.
Brandon
03-20-2008 09:06 AM
You can't do that with CCM. Windows 2003 allows connections from certain users. But if you want specific IP addresses, you will have to do an ACL on a firewall.
03-20-2008 09:07 AM
You know what I thought, if you install VNC, you can do this. VNC allows connections from certain IPs. rate me a 6 if you can! :)
