maintaining clock settings on a 2950 switch?
Answered Question
Mar 20th, 2008
I have set up external NTP synchronization on a 2950 switch which works fine while the switch is powered on. However if the switch is cycled with a "reload" command, the time established is way off once the switch comes back up. Is this the expected behaviour?
Thanks.
Correct Answer by Jon Marshall about 8 years 10 months ago
This is expected behaviour because the 2950 does not have a hardware clock which can keep the time between reboots. As long as your switch is resynching it's time via NTP it is nothing to worry about.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Thu, 03/20/2008 - 01:53
Jon
ocicat002 Thu, 03/20/2008 - 02:09
Thanks for confirming! I hadn't found this in the documentation yet.
Joseph W. Doherty Thu, 03/20/2008 - 04:20
BTW:
Also sometimes difficult finding mention whether the hardware supports an on-board calendar. I've found using the ntp update-calendar both often a fast method to help in determining this, and a great way to keep the calendar accurate across reboots/reloads (if you're using NTP).
