CallManager Operating System
Answered Question
Mar 20th, 2008
Hey all, hopefully this is a quick one. Does anyone know or can share a link, that discusses CallManager versions and the supported operating systems.
For example, CallManager v6.0 can run on O/S x and y.
I would like a quick snapshot for reference if possible :-)
Best regards
Darren
Correct Answer by woutereelen about 9 years 1 week ago
CCM 4.x --> Windows server (CCM installed on server)
CUCM 5.x --> Redhat Linux (CUCM integrated in Redhat OS)
CUCM 6.x --> Redhat Linux (CUCM integrated in Redhat OS)
Overall Rating: 5 (2 ratings)
lpezj Thu, 03/20/2008 - 04:12
  • Gold, 750 points or more
Darren,
You can look for Communications Manager compatibility matrixs when you can find hardware and software versions.
In this link you can find hardware compatibility:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
I this other you can find hardware and OS compatibility:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/mcs-server-os-0711.xls
In thi sother one, you can find all Callmaanger compatibility and versions: OS, phones, gateways, related products, etc.:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
You can access all this pages from this URL:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_device_support_tables_list.html
As a fast explanation, CallManager 4.X runs on Windows 2000, except version 4.3 that runs on 2003. Versions 5 and 6 uses Linux.
Hope this helps,
Juan Luis
Regarding
Rob Huffman Thu, 03/20/2008 - 05:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Darren,
I just wanted to add one doc to the great list provided by Juan Luis (my 5 points for your good work here JL :) The attachment below has some other good references for the various OS Minimums and versions.
Hope this helps!
Rob
Correct Answer
woutereelen Thu, 03/20/2008 - 08:08
