SDM mismatch
qwertys21
Hi All
I am getting an SDM mismatch on the stack.
I have a 3750-12G and a 3740-48G stacked together. I am making the 3750-12G the master by changing the priority to 15.
When i switched on the 3750-12G and the 3750-48G later and do a show switch it comes up with
Switch 1, Member, priority 1, smd mismatch
Switch 2, Master, priority 15, ready
Please how do I resolve this as it is not allowing me access the 3750-48G
CSCO11167812
Hardware Compatibility and SDM Mismatch Mode in Switch Stacks
The Catalyst 3750-12S switch supports desktop and aggregator Switch Database Management (SDM)
templates. All other Catalyst 3750 switches support only the desktop SDM templates.
All stack members use the SDM template configured on the stack master. If the stack master is using an
aggregator template, only Catalyst 3750-12S switches can be stack members. All other switches
attempting to join this switch stack enter SDM-mismatch mode. These switches can join the stack only
when the stack master is running a desktop
SDM template.
We recommend that your stack master use an aggregator template only if you plan to create a switch
stack of Catalyst 3750-12S switches. If you plan to have a switch stack with different Catalyst 3750
switch models, configure the stack master to use one of the desktop templates.
On http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swsdm.html is an explanation about this templates.
Gooed luck,
Michel
CSCO11167812
Here some text about SMD
5-10
Catalyst 3750 Switch Software Configuration Guide
OL-8550-01
Chapter 5 Managing Switch Stacks
Understanding Switch Stacks
when the stack master is running a desktop SDM template.
On http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swsdm.html is an explanation about configuring templates in a 3750 stack with differnt types.
Good luck,
Michel
