CCS / CAS in-band / out-of-band
Answered Question
Mar 20th, 2008
Found on wikipedia:
"Channel Associated Signaling (CAS), also known as Per-Trunk Signaling (PTS), is a form of digital communication signaling. As with most telecommunication signaling methods, it uses routing information to direct the payload of voice or data to its destination. With CAS signaling, this routing information is encoded and transmitted in the same channel as the payload itself. This information can be transmitted in the same band (in-band signaling) or a separate band (out-of-band signaling) to the payload."
I thought CAS was in-band signaling.
Do they mean with in-band and out-band the bands in the frequency spectrum?
Correct Answer by paolo bevilacqua about 9 years 1 month ago
Well, CAS with pulse dialing is actually out-of-band.
How it works, the A bit is toggled emulating the hook-switch in an analog telephone with rotary dial.
This is the only case that comes to mind, all the rest is in-band.
Overall Rating: 3.5 (2 ratings)
Jaime Valencia Thu, 03/20/2008 - 08:38
  • Cisco Employee,
  • Hall of Fame,
    2011
CAS means that if you have a T1 PRI you will get 24 voice calls, each DS0 contains within the same channel all the signaling for the call, that's in-band signaling
T1 PRI means you will get 23 calls, that's why it's referred ad 23B + 1D.
The D channel contains all the signaling for the other 23 channels, so it's not in the same DS0 as the voice, thus it's out of band
javalenc
if this helps, please rate
Correct Answer
paolo bevilacqua Thu, 03/20/2008 - 08:42
  • Hall of Fame,
    Founding Member
woutereelen Thu, 03/20/2008 - 08:53
That's what I've been looking for.
I knew wikipedia wouldn't lie! :-)
Thanks p.bevilacqua.
Also thanks to the other person for answering my question, but I am familiar with CAS and CCS. I just didn't know any scenario where the signaling of CAS is send out-of-band.
br,
Wouter
