Dialling Error
Mar 20th, 2008
CM version 4.13
I have a publisher and 2 subscribers. I installed the 2nd subscriber and all phones have registered to it. but it seems that any phone that had a callforward can no not be dialled or call out , I have reset the DBL monitor and CTI manager but still I can't call these phones neither can they dial out. Replication looks good. any ideas?
aamercado Thu, 03/20/2008 - 08:22
Try dblhelper which is usually part of your CM install so just do a search on the HD or download the upgrade prep tool to 4.3 and let it do a sanity check on your CM4.1
CUCM Upgrade Utility (UA),
Below is a tech note on forwarding issues
did you check for a Partition/calling Search Space issue?
