Diferent ssid's
Answered Question
Mar 20th, 2008
I have two interfaces in my WLC and one corporate wlan and other for public access in parks and squares. I would like that my public aps, model 1242, broadcast just my public ssid. Anybody knows how to do it?
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Rafael,
This is most possible :) The feature you are looking for is called WLAN Override :)
Enabling WLAN Override
By default, access points transmit all defined WLANs on the controller. However, you can use the WLAN Override option to select which WLANs are transmitted and which ones are not on a per access point basis. For example, you can use WLAN override to control where in the network the guest WLAN is transmitted or you can use it to disable a specific WLAN in a certain area of the network.
From this doc;
http://www.cisco.com/en/US/products/ps6366/products_configuration_guide_chapter09186a008076cbfd.html#wp1114777
Once you create a new WLAN, the WLAN > Edit page for the new WLAN appears. In this page you can define various parameters specific to this WLAN including General Policies, RADIUS Servers, Security Policies, and 802.1x Parameters.
**Check Admin Status under General Policies to enable the WLAN. If you want the AP to broadcast the SSID in its beacon frames, check Broadcast SSID.
Note: You can configure up to sixteen WLANs on the controller. The Cisco WLAN Solution can control up to sixteen WLANs for Lightweight APs. Each WLAN has a separate WLAN ID (1 through 16), a separate WLAN SSID (WLAN name), and can be assigned unique security policies. Lightweight APs broadcast all active Cisco WLAN Solution WLAN SSIDs and enforce the policies that you define for each WLAN.
From this good doc;
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml#c3
The most popular way to mitigate the problem of having to access each AP individually (when using WLAN Override) is to use WCS Templates for common requirement AP's. This way the WLAN Override function can be applied at the Template level and then pushed out to the various groups.
http://www.cisco.com/en/US/docs/wireless/wcs/4.0/configuration/guide/wcstemp.html#wp1072198
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Thu, 03/20/2008 - 07:01
Hi Rafael,
From this doc;
From this good doc;
Hope this helps!
Rob
Rob Huffman Mon, 03/24/2008 - 07:00
Hi Rafael/Pirate,
Glad to have been some small help here :)
Take care,
Rob
rsumpter Mon, 03/24/2008 - 08:46
Note: If using WCS to apply the WLAN Override function with a template be sure to reboot the AP when the template is applied. If the AP isn't rebooted all SSIDs in the WLC are still on the AP until the reboot occurs. We found this out the hard way.
Trending Topics - Security & Network
