Etherchannlel between switches
qwertys21
I have configured the stack and this is now working. Now I have the set up as in the diagram and want to configure etherchannel between the Cat 2960s and the stack as shown.
On the Cat 2960 SwA I have
Int g0/1
Switchport mode access
Switchport access vlan 2
Channel-group 1 mode desireable non-silent
Int g0/2
On the Cat 2960 SwB I have
Int g0/1
Channel-group 2 mode desireable non-silent
Int g0/2
On the Cat 2960 SwC I have
Int g0/1
Channel-group 3 mode desireable non-silent
Int g0/2
Interface port-channel 1
Interface port-channel 2
Interface port-channel 3
On the Stack
I have
SwD/SwE
Int g1/0/49
Int g2/0/1
Int g1/0/50
Int g2/0/2
Int g1/0/51
Int g2/0/3
Channel-group 3 mode désirable non-silent
But it is not allowing me to to enter
Channel-group 3 mode désirable non-silent on SwD/SwE
It is rejecting it. How can I do this?.
Is the above a good way to connect these using etherchannel
Am I going the right way, and if now how else can I connect this?
7 Replies 7
glen.grant
Won't work , you can't use PAGP to negotiate the channel when using crosstack etherchannel on the 3750's . You will have to use LACP or force the channels on in the 3750 .
On the 3750 and 2960's just use
channel-group X mode active
Thank you
I will try this.
But please can you tell me if the design concept is right?
Me having 3 port channel to 3 of the 2960, is that correct?
Should work fine .
I have put
channel-group 1 active on all the interfaces but it is still not working.
Please can you help?
I get this:
%With PAgP enabled, all ports in the Channel should belong to the same switch
Command rejected (Port-channel1, Gi1/0/49): Invalid etherchnl mode
Use your original config with the changes shown.
Int g0/1
Channel-group 1 mode active
Int g0/2
Int g0/1
Channel-group 2 mode active
Int g0/2
Int g0/1
Channel-group 3 mode active
Int g0/2
On the Stack
I have
SwD/SwE
Int g1/0/49
Int g2/0/1
Int g1/0/50
Int g2/0/2
Int g1/0/51
Int g2/0/3
You would not put channel group 1 on all interfaces , follow your original config , instead of using channel-group X mode desirable use channel-group X mode active . Do you have physical links on all before starting this ? Also try to do both sides of the link as close together as possible , just input your commands on both interfaces at the same time useing the interface range command. Look in the logs and it will tell you why its not coming up .
