VPN Concentrator Group Username and Password Encryption
Mar 20th, 2008
I have a number of remote access groups defined on my 3030. Many of the groups were defined by others. Is there a way to view the passwords defined for each group?
Overall Rating: 3 (1 ratings)
markus.jahnke Thu, 03/20/2008 - 14:20
Hi!
There's an option within the concentrators file management to save the config as xml file, which contains the passwords in clear text. (At least for firmware 4.1 - 4.7.)
rmeans Fri, 03/21/2008 - 06:01
I am running 4.7.2k. I found the xml export option. I do so and create a file named "file.xml". When I view the file, the passwords are still encrypted.
rmeans Thu, 04/17/2008 - 09:03
Using the link, I am able to enter the encrypted group password from the vpn client pcf file (profile). Using the concentrator config file and the encrypted group password, I was not able to decrypt.
Useful, thanks.
