How to transfer a caller to the VM box?
Mar 20th, 2008
For example, the assistant pick up her boss's phone and talk with the caller, then she want to transfer the user directly to her boss's VM box, let him leave a message.
We are using Unity Connection 1.2.
Once we use Nortel VM, we achieve this feature by transfer the caller to a express messaging.
Jason Bree Thu, 03/20/2008 - 07:31
We use **XXXXXXX to transfer directly to mail.
Hope that helps
jeffshen1215 Thu, 03/20/2008 - 07:36
What is XXXX represents? Extension number or VM pilot number? Thanks,
I tried as you said, but failed. I wonder the code "**" has not been configured in our system yet.
Jason Bree Thu, 03/20/2008 - 07:52
Under Device you need to configure a CTI route point for transfer to VM and set the DN as **458xxxx in my case.
jeffshen1215 Thu, 03/20/2008 - 08:04
Thanks Rob and Jason, I appreciate your help!
Your answer solved 50% of my problem. I didn't mention at the begining, our system is an integration of 50% Nortel and 50% Cisco, both of the users are using Unity VM.
So you helped me to solve the Cisco part, but for Nortel User, I still need to find the solution...(Current connection: Nortel PBX---PIMG--cisco Unity)
Jason Bree Thu, 03/20/2008 - 08:17
We have the same set up right now. Told nortel users they are out of luck till their site gets IP phones
