ip precedence-3640
Mar 20th, 2008
I'm trying to forward based on IP-precedence bits
pc--->switch--->c1700----->c3640---->3750
The 1700 successfully classifies packets with "ip-precedence critical" (5).
Next step is for Cisco 3640 to prioritize forwarding...how can I do this with a 3640 with older IOS image; this can be upgraded if necessary, but there is limited memory.
On the 3640, do I need an IOS with QOS to "trust" the ip-precedence set on the 1700 ?
Is there a simple way to have the 3640 to forward packets with ip-precedence of 5
Overall Rating: 5 (1 ratings)
boblutton Thu, 03/20/2008 - 09:12
THis is the route-map in use on the 1700...
It is definately setting the precedence, but when the 3640 gets the packet, how can I force it to read and prioritize the packet ?
route-map prior13net4 permit 20
match ip address 106 107
set ip precedence critical
Joseph W. Doherty Fri, 03/21/2008 - 10:39
If your 3640 IOS supports CBWFQ, on your outbound FastEthernet interface (assume Ethernet because of downsteam 3750), you could first try:
policy-map Yourname
interface Fastethernet 0
service policy output Yourname
or
class-map yourclassname
match precedence critical
policy-map Yourname
class yourclassname
priority # (Kbps)
