Offset-lists and RIP ?
Answered Question
Mar 20th, 2008
IOS 12.4 under router rip:
"offset-list Add or subtract offset from rip metric".
Then when I type 'offset-list 1 out ?'
I get the following <0-16> Offset.
So ..... How can you subtract from the metric using 0-16 ? Also what would be the purpose of adding or subtracting 0 ???.
Is this s/w just a bit buggy or am I missing something ?
Phil.
Correct Answer by Edison Ortiz about 8 years 11 months ago
So I am assuming the word 'subtract' is erronous in the IOS ???
Yes. The online help is useful for additional command options. Never trust what the explanation says, consult the documentation.
__
Edison.
Overall Rating: 5 (1 ratings)
philipbarker Thu, 03/20/2008 - 11:38
Hi Edison,
Just use the '?' under router rip and you will see 'Offset-list Add or subtract offset from RIP metrics' as one of the options. If you type 'offset-list 1 in ?' at this point the IOS offers '<0-16> Offset'.
I cannot see the point in offering 0 as an option nor can I see the ability to use -ve integers. So I am assuming the word 'subtract' is erronous in the IOS ???
Phil.
Correct Answer
Edison Ortiz Thu, 03/20/2008 - 11:50
__
Edison.
