Pix 515E second internal IP address
Answered Question
Mar 20th, 2008
Hi everyone quick question how do you configure another ip address on a pix? I already have an in and out what I was looking to do is add another in address. I tried just doing: ip address inside 192.168.50.25 255.255.255.0 but ended up changing my inside ip address thus locking me out of the PIX. How do I add a secondary interface? Thank you in advance
Correct Answer by Jon Marshall about 9 years 1 month ago
Warren
interface ethernet2 100full
ip address intf2 192.168.50.24 255.255.255.0
Then connect the intf2 port to your switch. Obviously it needs to be in a different vlan than the one your inside interface connects to.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 03/20/2008 - 10:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Warren
Pix firewalls do not allow secondary IP addresses on an interface so you have 2 choices really
1) Use a spare interface on the pix and address this from a different subnet range
2) If you don't have a spare interface you can run 802.1q on the inside interface and give yourself additional interfaces that way.
Jon
wgranada1 Thu, 03/20/2008 - 10:48
Hi Jon;
Ok I have a spare interface on the pix, I tried to put an ip address on it but it changed my original inside interface and I locked myself out again. I was trying to add and ip address to:
no ip address intf2
interface2 but I keep changing my original inside ip and locking myslef out. I think I
know what I'm doing wrong but afraid to try it
now as I keep locking myself out. This is probably wrong:
I know this is wrong as I lock myself out
to add a ip address on interface2, which is free what do I need to do?
Jon Marshall Thu, 03/20/2008 - 10:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Warren
If you already have an inside interface called "inside" then you will need to give your spare interface a different name on the interface.
Which version of software are you running and could you post config.
Jon
wgranada1 Thu, 03/20/2008 - 11:02
Sure please see attached
I wanted to use ethernet2/intf2 add the following IP address to is
192.168.50.24
thank you for your help!!
Correct Answer
Jon Marshall Thu, 03/20/2008 - 11:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Warren
Jon
wgranada1 Thu, 03/20/2008 - 11:24
Thanks Jon for the information!!!! Have a good weekend!
