Identity Nat on FWSM
I am using a fwsm with 3.2.5 Release and i found some strange static-nat behavior.
My nat configuration looks like this:
static (inside,outside) 172.23.253.6 172.23.0.100 netmask 255.255.255.255
route inside 172.23.0.0 255.255.0.0 x.y.z.v
Everything works fine for some time, but then the fwsm creates a identity xlate which looks like this:
NAT from inside:172.23.0.100 to outside:172.23.251.6 flags si
NAT from inside:172.23.251.6 to outside:172.23.251.6 flags Ii
Then connections doesn't work any more, because the 172.23.251.6 is no longer translated to 172.23.0.100
If i remove the route, this identity xlate entry is not created.
So for me it's some kind of bug, because the pix has no reason to create a second xlate entry if i am using statics
From pix 6.3 (http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/s.html#wp1026694 , look to nat order)
So the question is:
Is this behavior right? Or has cisco changed the nat order of their firewalls? Why should a route be preferd to a static nat entry?
Thanks a lot & Br
Ronald
htarra Wed, 03/26/2008 - 12:42
  • Bronze, 100 points or more
With FWSM version 3.x or higher, the blade, by default, will route traffics so you do NOT have to do anything. You still need ACL to go from low to high but NOT from high to low. If you still use fwsm version 2.x, you still NEED to perform no NAT to go from high to low.The static statement works by creating pre-existing translations, so that when traffic enters, it matches an
existing translation. If you translate the entire class B network, traffic destined for the farm would match translations for both the farm and the admin networks. This would produce unexpected and unpredictable behavior.
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.1/user/guide/pxpage.html
http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/configuration/guide/nat.html
cisco24x7 Wed, 03/26/2008 - 17:09
  • Silver, 250 points or more
"With FWSM version 3.x or higher, the blade, by default, will route traffics so you do NOT have to do anything"
Yes that is true BUT.....
If you have, let say VLAN100 (security 100),
VLAN2 (security level 0) and VLAN3 (security
level 10) and you have the following:
nat (vlan100) 1 0 0
global (vlan2) 1 interface
Once you do that, you have to do the following if you want to go from vlan100 to
vlan3 without any translation:
static (vlan100,vlan3) x.x.x.x x.x.x.x net/24
In other words, you're back to version 2.x
over again.
my 2c.
CCIE Security
static (vlan100,vlan3) 1.x.x
