Ether channel
Mar 20th, 2008
I have 2 Layer 3 Cisco 3560G switches,I have cascaded these two.
Now I have 30 bladed servers in Server VLAN,in that is it necessary to configure the Server VLAN in both 3560G switches.
Then there is a SUN NAS server,which has 2 GBIC NIC card,they have configured the BONDING,means bundling 2 gbic like,in that case we have to also configure the 2 switch port into single 2gbic unidirectional or 2GB bidirectional .Means basically we have to bundle 2 GIBIC port into single 2GBIC unidirectional or 4 GBIC bidirectional,we did fast etherchannel ,but it is not happening,Please clarify why it is not doing?How to do a BONDING in the Cisco switch.
Please help me to resolve the issue.
Thnaks and Regards,
S.venkataraman.
Overall Rating: 4 (1 ratings)
Edison Ortiz Thu, 03/20/2008 - 10:42
  • Hall of Fame,
    Founding Member
Etherchanneling is only supported when sourcing from the same switch towards the same destination.
You can't have etherchanneling configured among 2 switches with the 3560G model. You could accomplish this task with the 3750G model which provides cross-stack features.
Posting your current config will help troubleshooting your case a lot better.
HTH,
__
Edison.
