Using wireshark for sniffing wlc 5.x HOW?
Answered Question
Mar 20th, 2008
release notes for wlc software 5.x state that it is possible to use a sniffer AP and wireshark to capture radia data. Setting up the AP is described but how do i setup the wireshark workstation to retrieve the traffic? Is there something like a daemon mode where wireshark listens on port xy for incomming packages from the AP or ...
So can someone lighten me?
regards Martin
Correct Answer by sabhasin about 9 years 2 months ago
Martin - yes, indeed that's possible. However, the fine print is that it's a specially built wireshark version that understands the custom packet format which is used to encapsulate LWAPP between WLC and Wireshark machine. Please open a TAC case and ask the TAC engineer to get this special build for you. Hope that helps.
Overall Rating: 4 (1 ratings)
Correct Answer
sabhasin Fri, 03/21/2008 - 11:23
jozefburak Thu, 07/31/2008 - 10:45
Hi Martin, do you have already contact TAC engineer for this wireshark edition? Could you share it? I have the same problem.
Jozef
m.hierling Thu, 07/31/2008 - 21:27
Yes, but they send me a patched windows version. cant work with that because i have no Windows sniffer at my monitor ports.
anyway, i have deleted the software, sorry.
Martin
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
