NAT Overloading: Restricting ports to a higher value?
Mar 20th, 2008
From the below, I've did a NAT overloading (IOS) for traffic going from 11.11.11.11 to 10.22.22.0/24. But having read in some doc that for icmp traffic, PAT will use ports starting from 0, I'm wondering if there's a way to set the port to a higher port value.
From the below debug, it is currently using port 80. Is there any way to restrict the port to a higher number, e.g. 1000+ ?
Thanks.
*Mar 3 03:32:23.751: NAT: map match test
*Mar 3 03:32:23.751: NAT: [0] Allocated Port for 11.11.11.11 -> 10.22.22.1: wanted 8 got 8
*Mar 3 03:32:23.755: NAT: i: icmp (11.11.11.11, 8) -> (10.22.22.2, 8) [40]
*Mar 3 03:32:23.759: NAT: s=11.11.11.11->10.22.22.1, d=10.22.22.2 [40]
amritpatek Wed, 03/26/2008 - 12:45
  • Silver, 250 points or more
This is not possible for ICMP traffic since selecting ports is only possible for TCP and UDP protocols.
