IPS Signature Export for Audit
Answered Question
Mar 20th, 2008
  • Blue, 1500 points or more
We have an auditor that wants to see all active signatures from our version 6.0(3) SSM-10s.
Is there any way to export all active signatures in report form? The auditor says he has received this from other clients.
We use CSM, ASDM, and MARS but I don't see any export options that address this.
Thanks!
Correct Answer by marcabal about 9 years 4 months ago
The easiest method here is bring up IDM and go to the signatures configuration.
NOTE: You can use the viewing filters in IDM to only show signatures matching a certain criteria (like enabled).
Use your mouse to highlight/select all of the signatures.
NOTE: Do not use the Select All button.
Now use Ctrl-C to copy all of the entries.
Open Excel
Select the cell A1 and use Ctrl-V to paste the values into the spreadsheet.
Overall Rating: 5 (2 ratings)
Correct Answer
marcabal Thu, 03/20/2008 - 12:02
  • Cisco Employee,
Open Excel
dgahm Thu, 03/20/2008 - 12:32
Marc,
I had tried the Select All. Works fine your way!
Regards, Dave
rhermes Fri, 03/21/2008 - 09:23
  • Gold, 750 points or more
Now, if only CSM could do that trick....
dennis.perez Tue, 04/15/2008 - 09:48
Can I used this method to export customer signatures from the IDS and import them into another IDS?
rhermes Wed, 04/16/2008 - 08:14
You can use CSM (free 90 day trial) to move custom sigs between sensors. Import the sensor with the custom sigs, make a policy out of the configuration and apply it to your other sensors.
attmidsteam Wed, 04/16/2008 - 10:01
  • Silver, 250 points or more
This method works very well, we used it to migrate our sensor policies from VMS to CSM.
