2nd call line display
Mar 20th, 2008
If you have 2 lines on a phone and one is active in call - a call to the 2nd line can only flash/beep/ring.....is there a way to have it show up on the screen?
It does this for a 2nd call to the line that is active but not another line.
Manish
Rob Huffman Thu, 03/20/2008 - 18:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Manish,
Try changing the System setting Auto-Line Select. With this Enabled the Display Focus (and Softkeys) always switch to the new incoming call.
Also available on an individual phone via this setting;
Device>Phone>Phone Configuration>Product Specific Configuration>Auto Line Select>Enabled
Hope this helps!
Rob
