SIP phone lost registration on CCME
Mar 20th, 2008
I use CCME 4.1 with dlink DPH-300S SIP IP phone.
All works fine, but ip phone after same time unregistred from CCME and user should manually register phone again.
Can I configure CCME to avoid proccess re-registring SIP ip phone?
My conf:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol none
registrar server
voice register global
mode cme
source-address port 5060
max-dn 20
max-pool 58
time-format 24
date-format D/M/Y
file text
create profile sync 0407455740166572
voice register dn 10
number 2003
allow watch
label 592613
voice register pool 10
id mac 001B.111E.1D33
number 1 dn 10
dtmf-relay sip-notify
username user password user
codec g711ulaw
Thank you very much
Paolo Bevilacqua Thu, 03/20/2008 - 14:26
I have the same issue with a Siemens phone. it worked fine for months, now mysteriously the registration is lost after some time.
I had not got the time to troubleshoot the root cause of that, perhaps you can, by looking at "debug ccsip message" with "term mon".
A possible workaround would be configuring a voip DP pointing to the phone's address.
EDIT: I see that your config, username is not same as number, well for precaution, make it so it is.
Mikhail Chernyakov Thu, 03/20/2008 - 23:32
I disclose that Ip phone unregistred exactly as set in
voice service voip
registrar server expires max 120 min 60
The max time is one day... Can I change this situation?
Paolo Bevilacqua Fri, 03/21/2008 - 06:13
Try lowering the min and check with debug that phone is periodically refreshing. Most phones do that every minute or so.
