03-20-2008 01:55 PM - edited 03-11-2019 05:20 AM
I received an upgrade AES/3DES license from Cisco and keyed it into my PIX 515. The update was made but now the PIX shows the following warning:
Warning ---> Insufficient Memory for UR/FO/FO-AA Licenses<--- Minimum 128MB needed for UR/FO/FO-AA Licenses on this platform. Any idea how to fix this issue? I don't see a need to upgrade RAM as my other PIX515 has the identical license with no warning.
Thanks for any help!
03-21-2008 02:12 AM
Is this pix in failover ? can you post show version here ?
03-21-2008 12:03 PM
Here is the sh ver:
pixfirewall> sh ver
Cisco PIX Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(2)
Compiled on Wed 22-Nov-06 14:16 by builders
System image file is "flash:/pix722.bin"
Config file at boot was "startup-config"
pixfirewall up 15 secs
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: Ext: Ethernet0 : address is 0050.54ff.8927, irq 10
1: Ext: Ethernet1 : address is 0050.54ff.8928, irq 7
2: Ext: Ethernet2 : address is 00e0.b605.992b, irq 11
3: Ext: Ethernet3 : address is 00e0.b605.992a, irq 11
4: Ext: Ethernet4 : address is 00e0.b605.9929, irq 11
5: Ext: Ethernet5 : address is 00e0.b605.9928, irq 11
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
Serial Number: [EDITED]
Running Activation Key: [EDITED]
Configuration has not been modified since last system restart.
** **** WARNING *** WARNING *** WARNING *** WARNING *** WARNING **** **
** !!! ---> Insufficient Memory for UR/FO/FO-AA License(s) <--- !!! **
** Minimum 128 Mb needed for UR/FO/FO-AA License(s) on this platform! **
pixfirewall>
03-21-2008 12:11 PM
Cisco PIX 515/515E Security Appliance version 7.x requirements :-
⢠64 MB on Restricted models
⢠128 MB Unrestricted, Failover, and Failover-Active/Active models
HTH !!
