Forwarding based on URL
Gilles Dufour Fri, 03/21/2008 - 05:28
  • Cisco Employee,
do you have an SSL module ?
This will be require for such requirement.
Regarding the vips, you can have a single one for both hostname, but be aware that certificates contain the name of the site and client browsers do check that the certificate received from a site does match the name of the site typed in the url.
So, you will have to request a special certificate for *.toto.com from your certificate authority.
After that, this is quite easy to configure the CSS.
Gilles.
