kluu_ironport Thu, 03/20/2008 - 23:36
Yes, if you download the AsyncOS to a local upgrade server/Apache server, you can use that to upgrade both of your C-series appliances.
If i do a download for Asyncos for a C10 or C100, can I use the same download on a C!%) and vice versa?
Doc_ironport Mon, 03/24/2008 - 01:50
That's certainly possible, but you're got to do it right...
By default AsyncOS upgrade files are only good for a single system - based on the serial number. If you download an upgrade for a one system and try and use it on another it will fail as the serial numbers won't match.
You can get around this by downloading a single file which is good for multiple systems. The easiest way to do this is to go to http://downloads.ironport.com/form.html and enter the multiple serial numbers, separated by a comma. The resulting file will then be good to upgrade all of the systems you enter (Presuming that it's a supported upgrade path/etc)
imanyere_ironport Mon, 03/24/2008 - 17:45
That puts me on a disadvantage coz i have really poor links here. had downloaded using a certain appliance Serial number, hoping it would work on another.
Doc_ironport Tue, 03/25/2008 - 17:00
Unfortunately if you've already downloaded the upgrade for one system there's nothing you can do to use it on another system - the upgrades are encrypted/checksumed/etc based on the serial number(s), so it's not even possible to modify it to work on another system.
At least you'll know for the future :)
imanyere_ironport Wed, 03/26/2008 - 07:29
for sure thanks. now I know better.
